subject line
how can I make every subject line, in every folder bigger?
it was complicated coz of these bookmarks of sfhowes,your step by step advice was/is a good idea and now i am very glad...many thanks for that...
All Replies (4)
To increase all the fonts, see this topic about changing a single preference:
https://support.mozilla.org/en-US/questions/1269361
The discussion includes a method to adjust just the Subject line (Threads Pane font) with css:
https://support.mozilla.org/en-US/questions/1269361?page=2#answer-1274848
too complicated.. i hope the new update will make it easy to adjust it...
What is too complicated ?
To increase font size in the UI is not complicated. Look at the image below to see how simple it is.
  • Menu app icon > Options > Advanced > 'General' tab
  • click on 'Config Editor' button and accept risk.
  • TYpe : pixels
  • double click on line :layout.css.devPixelsPerPx
  • Enter a new number eg: 1.5 and click on OK
It will show instant effect, so it's easy to adjust the number until it suits you.
